Broken links from 'listAction' page.
thepurpleblob
I have redirected my home page to
Route::get('/', '\Aimeos\Shop\Controller\CatalogController@listAction')->name('aimeos_list');
This works fine, I get a listing of my products. However, the links don't work when I click on any part of the product. A typical URL looks like this....
http://127.0.0.1:8000/e/e/eeab37ec_1016 ... /CAL2021/0
404 error. However, if I cut this down to http://127.0.0.1:8000/shop/CAL2021/0 then I see the product page correctly.
Where is that extra image junk coming from?
Re: Broken links from 'listAction' page.
Is this from the cache? You can clear the cache using
Can you post the output of
php artisan aimeos:clearCode: Select all
composer showProfessional support and custom implementation are available at Aimeos.com
thepurpleblob
I already tried clearing the cache. It didn't work.
On the list page, it's also all the first, lat and so on links too, so it would appear this extra 'stuff' is finding its way into the basic IRL.
Here is my composer output...
% composer show
aimeos/ai-admin-jqadm 2020.10.2 Aimeos Vue.js+Bootstrap admin interface
aimeos/ai-admin-jsonadm 2020.10.1 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html 2020.10.5 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi 2020.10.2 Aimeos JSON API extension
aimeos/ai-controller-frontend 2020.10.1 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs 2020.10.2 Aimeos ai-controller-jobs extension
aimeos/ai-gettext 2020.10.1 Aimeos Gettext extension
aimeos/ai-laravel 2020.10.2 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments 2020.10.1 Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer 2020.10.1 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core 2020.10.5 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel 2020.10.1 Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2...
aimeos/map 1.8.0 Easy and elegant handling of PHP arrays as array-like map objects similar to jQuery and Laravel Collections
clue/stream-filter v1.5.0 A simple and modern approach to stream filtering in PHP
composer/installers v1.9.0 A multi-framework Composer library installer
dnoegel/php-xdg-base-dir v0.1.1 implementation of xdg base directory specification for php
doctrine/cache 1.10.2 PHP Doctrine Cache library is a popular cache implementation that supports many different drivers such as r...
doctrine/dbal 2.12.0 Powerful PHP database abstraction layer (DBAL) with many features for database schema introspection and man...
doctrine/event-manager 1.1.1 The Doctrine Event Manager is a simple PHP event system that was built to be used with the various Doctrine...
doctrine/inflector 2.0.3 PHP Doctrine Inflector is a small library that can perform string manipulations with regard to upper/lowerc...
doctrine/instantiator 1.3.1 A small, lightweight utility to instantiate objects in PHP without invoking their constructors
doctrine/lexer 1.2.1 PHP Doctrine Lexer parser library that can be used in Top-Down, Recursive Descent Parsers.
dragonmantank/cron-expression v2.3.1 CRON for PHP: Calculate the next or previous run date and determine if a CRON expression is due
egulias/email-validator 2.1.22 A library for validating emails against several RFCs
facade/flare-client-php 1.3.7 Send PHP errors to Flare
facade/ignition 1.16.3 A beautiful error page for Laravel applications.
facade/ignition-contracts 1.0.2 Solution contracts for Ignition
fideloper/proxy 4.4.1 Set trusted proxies for Laravel
filp/whoops 2.9.0 php error handling for cool kids
fzaninotto/faker v1.9.1 Faker is a PHP library that generates fake data for you.
guzzlehttp/guzzle 6.5.5 Guzzle is a PHP HTTP client library
guzzlehttp/promises 1.4.0 Guzzle promises library
guzzlehttp/psr7 1.7.0 PSR-7 message implementation that also provides common utility methods
hamcrest/hamcrest-php v2.0.1 This is the PHP port of Hamcrest Matchers
jakub-onderka/php-console-color v0.2
jakub-onderka/php-console-highlighter v0.4 Highlight PHP code in terminal
laminas/laminas-diactoros 2.4.1 PSR HTTP Message implementations
laminas/laminas-zendframework-bridge 1.1.1 Alias legacy ZF class names to Laminas Project equivalents.
laravel/framework v6.19.1 The Laravel Framework.
laravel/tinker v1.0.10 Powerful REPL for the Laravel framework.
laravel/ui v1.2.0 Laravel UI utilities and presets.
league/commonmark 1.5.6 Highly-extensible PHP Markdown parser which fully supports the CommonMark spec and Github-Flavored Markdown...
league/flysystem 1.1.3 Filesystem abstraction: Many filesystems, one API.
league/mime-type-detection 1.5.1 Mime-type detection for Flysystem
mockery/mockery 1.4.2 Mockery is a simple yet flexible PHP mock object framework
moneyphp/money v3.3.1 PHP implementation of Fowler's Money pattern
monolog/monolog 2.1.1 Sends your logs to files, sockets, inboxes, databases and various web services
myclabs/deep-copy 1.10.1 Create deep copies (clones) of your objects
nesbot/carbon 2.41.5 An API extension for DateTime that supports 281 different languages.
nikic/php-parser v4.10.2 A PHP parser written in PHP
nunomaduro/collision v3.0.1 Cli error handling for console/command-line PHP applications.
nyholm/psr7 1.3.1 A fast PHP7 implementation of PSR-7
omnipay/common v3.0.4 Common components for Omnipay payment processing library
omnipay/sagepay 3.2.3 Sage Pay driver for the Omnipay PHP payment processing library
opis/closure 3.6.0 A library that can be used to serialize closures (anonymous functions) and arbitrary objects.
paragonie/random_compat v9.99.99 PHP 5.x polyfill for random_bytes() and random_int() from PHP 7
phar-io/manifest 1.0.3 Component for reading phar.io manifest information from a PHP Archive (PHAR)
phar-io/version 2.0.1 Library for handling version information and constraints
php-http/discovery 1.12.0 Finds installed HTTPlug implementations and PSR-7 message factories
php-http/guzzle6-adapter v1.1.1 Guzzle 6 HTTP Adapter
php-http/httplug v1.1.0 HTTPlug, the HTTP client abstraction for PHP
php-http/message 1.9.1 HTTP Message related tools
php-http/message-factory v1.0.2 Factory interfaces for PSR-7 HTTP Message
php-http/promise 1.1.0 Promise used for asynchronous HTTP requests
phpdocumentor/reflection-common 2.2.0 Common reflection classes used by phpdocumentor to reflect the code structure
phpdocumentor/reflection-docblock 5.2.2 With this component, a library can provide support for annotations via DocBlocks or otherwise retrieve info...
phpdocumentor/type-resolver 1.4.0 A PSR-5 based resolver of Class names, Types and Structural Element Names
phpoption/phpoption 1.7.5 Option Type for PHP
phpspec/prophecy 1.12.1 Highly opinionated mocking framework for PHP 5.3+
phpunit/php-code-coverage 7.0.10 Library that provides collection, processing, and rendering functionality for PHP code coverage information.
phpunit/php-file-iterator 2.0.2 FilterIterator implementation that filters files based on a list of suffixes.
phpunit/php-text-template 1.2.1 Simple template engine.
phpunit/php-timer 2.1.2 Utility class for timing
phpunit/php-token-stream 3.1.1 Wrapper around PHP's tokenizer extension.
phpunit/phpunit 8.5.8 The PHP Unit Testing framework.
psr/container 1.0.0 Common Container Interface (PHP FIG PSR-11)
psr/http-factory 1.0.1 Common interfaces for PSR-7 HTTP message factories
psr/http-message 1.0.1 Common interface for HTTP messages
psr/log 1.1.3 Common interface for logging libraries
psr/simple-cache 1.0.1 Common interfaces for simple caching
psy/psysh v0.9.12 An interactive shell for modern PHP.
ralouphie/getallheaders 3.0.3 A polyfill for getallheaders.
ramsey/uuid 3.9.3 Formerly rhumsaa/uuid. A PHP 5.4+ library for generating RFC 4122 version 1, 3, 4, and 5 universally unique...
scrivo/highlight.php v9.18.1.3 Server side syntax highlighter that supports 185 languages. It's a PHP port of highlight.js
sebastian/code-unit-reverse-lookup 1.0.1 Looks up which function or method a line of code belongs to
sebastian/comparator 3.0.2 Provides the functionality to compare PHP values for equality
sebastian/diff 3.0.2 Diff implementation
sebastian/environment 4.2.3 Provides functionality to handle HHVM/PHP environments
sebastian/exporter 3.1.2 Provides the functionality to export PHP variables for visualization
sebastian/global-state 3.0.0 Snapshotting of global state
sebastian/object-enumerator 3.0.3 Traverses array structures and object graphs to enumerate all referenced objects
sebastian/object-reflector 1.1.1 Allows reflection of object attributes, including inherited and non-public ones
sebastian/recursion-context 3.0.0 Provides functionality to recursively process PHP variables
sebastian/resource-operations 2.0.1 Provides a list of PHP built-in functions that operate on resources
sebastian/type 1.1.3 Collection of value objects that represent the types of the PHP type system
sebastian/version 2.0.1 Library that helps with managing the version number of Git-hosted PHP projects
swiftmailer/swiftmailer v6.2.3 Swiftmailer, free feature-rich PHP mailer
symfony/console v4.4.15 Symfony Console Component
symfony/css-selector v5.1.7 Symfony CssSelector Component
symfony/debug v4.4.15 Symfony Debug Component
symfony/error-handler v4.4.15 Symfony ErrorHandler Component
symfony/event-dispatcher v4.4.15 Symfony EventDispatcher Component
symfony/event-dispatcher-contracts v1.1.9 Generic abstractions related to dispatching event
symfony/finder v4.4.15 Symfony Finder Component
symfony/http-client-contracts v2.3.1 Generic abstractions related to HTTP clients
symfony/http-foundation v4.4.15 Symfony HttpFoundation Component
symfony/http-kernel v4.4.15 Symfony HttpKernel Component
symfony/mime v5.1.7 A library to manipulate MIME messages
symfony/polyfill-ctype v1.19.0 Symfony polyfill for ctype functions
symfony/polyfill-iconv v1.19.0 Symfony polyfill for the Iconv extension
symfony/polyfill-intl-idn v1.19.0 Symfony polyfill for intl's idn_to_ascii and idn_to_utf8 functions
symfony/polyfill-intl-normalizer v1.19.0 Symfony polyfill for intl's Normalizer class and related functions
symfony/polyfill-mbstring v1.19.0 Symfony polyfill for the Mbstring extension
symfony/polyfill-php70 v1.19.0 Symfony polyfill backporting some PHP 7.0+ features to lower PHP versions
symfony/polyfill-php72 v1.19.0 Symfony polyfill backporting some PHP 7.2+ features to lower PHP versions
symfony/polyfill-php73 v1.19.0 Symfony polyfill backporting some PHP 7.3+ features to lower PHP versions
symfony/polyfill-php80 v1.19.0 Symfony polyfill backporting some PHP 8.0+ features to lower PHP versions
symfony/process v4.4.15 Symfony Process Component
symfony/psr-http-message-bridge v2.0.2 PSR HTTP message bridge
symfony/routing v4.4.15 Symfony Routing Component
symfony/service-contracts v2.2.0 Generic abstractions related to writing services
symfony/translation v4.4.15 Symfony Translation Component
symfony/translation-contracts v2.3.0 Generic abstractions related to translation
symfony/var-dumper v4.4.15 Symfony mechanism for exploring and dumping PHP variables
tecnickcom/tcpdf 6.3.5 TCPDF is a PHP class for generating PDF documents and barcodes.
theseer/tokenizer 1.2.0 A small library for converting tokenized PHP source code into XML and potentially other formats
tijsverkoyen/css-to-inline-styles 2.2.3 CssToInlineStyles is a class that enables you to convert HTML-pages/files into HTML-pages/files with inline...
vlucas/phpdotenv v3.6.7 Loads environment variables from `.env` to `getenv()`, `$_ENV` and `$_SERVER` automagically.
voku/portable-ascii 1.5.3 Portable ASCII library - performance optimized (ascii) string functions for php.
webmozart/assert 1.9.1 Assertions to validate method input/output with nice error messages.Re: Broken links from 'listAction' page.
Very strange! Can you give aimeos/aimeos-laravel:2020.10.x-dev a try?
composer req aimeos/aimeos-laravel:2020.10.x-devProfessional support and custom implementation are available at Aimeos.com
thepurpleblob
That fixed it
