Integrate Blog into Aimeos
QuốcTrungNguyễnHoàng
Post by QuốcTrungNguyễnHoàng » 03 Nov 2020, 08:15
I have 3 tables in DB (posts, post_tag, tags).
I'm following document and create file structure like this
But i don't understand what should implement in Factory and Standard file to pass and maganage data in view file
Re: Integrate Blog into Aimeos
Post by aimeos » 03 Nov 2020, 08:21
Post by QuốcTrungNguyễnHoàng » 03 Nov 2020, 08:37
Yes,
I read it, but i feel not comfortable when use php aimeos core syntax.
I want to convert php file -> blade.php
How can i pass data from Standard file method to blade view and access data from blade file?
Post by aimeos » 04 Nov 2020, 08:19
Using Blade templates in the admin backend should work the same way as for the frontend. Here's the documentation:
https://aimeos.org/docs/latest/laravel/ ... -templates
