changing primary media type on product page
mrmmc8
Post by mrmmc8 » 09 Nov 2020, 05:31
would it be possible to use video instead of image as the primary media for the product detail page?
Re: changing primary media type on product page
Post by aimeos » 10 Nov 2020, 09:53
You mean instead of the product image resp. the product image slideshow?
You will have to adapt the template/JS code an see if it works with the JS code:
https://github.com/aimeos/ai-client-htm ... bottom.php
resp: https://github.com/aimeos/ai-client-htm ... andard.php
If you get it to work, we would love to get a contribution from you :-)
mrmmc8
Post by mrmmc8 » 25 Dec 2020, 03:32
we are working on the function, would love to be intergrade into aimeos as part of the function
