must be of the type array
mateusanjosv
Post by mateusanjosv » 20 Nov 2020, 12:42
Good morning!
I'm breaking my head. I will be grateful for your help
Windows
Laravel: 8
Aimeos: "aimeos/aimeos-laravel": "~2020.10.x-dev",
Php: 7.3
Error: https://prnt.sc/vmtdv9
Argument 2 passed to Aimeos\MW\Config\Decorator\Memory::__construct() must be of the type array, null given, called in C:\Users\conta\Desktop\PARANHOS\laravel-auth\vendor\aimeos\aimeos-laravel\src\Aimeos\Shop\Base\Config.php on line 69
at C:\Users\conta\Desktop\PARANHOS\laravel-auth\vendor\aimeos\aimeos-core\lib\mwlib\src\MW\Config\Decorator\Memory.php:36
32▕ *
33▕ * @param \Aimeos\MW\Config\Iface $object Config object or decorator
34▕ * @param array $config Pre-cached non-shared configuration
35▕ */
➜ 36▕ public function __construct( \Aimeos\MW\Config\Iface $object, array $config = [] )
37▕ {
38▕ parent::__construct( $object );
39▕
40▕ $this->config = $config;
1 C:\Users\conta\Desktop\PARANHOS\laravel-auth\vendor\aimeos\aimeos-laravel\src\Aimeos\Shop\Base\Config.php:69
Aimeos\MW\Config\Decorator\Memory::__construct(Object(Aimeos\MW\Config\PHPArray))
2 C:\Users\conta\Desktop\PARANHOS\laravel-auth\vendor\aimeos\aimeos-laravel\src\Aimeos\Shop\Base\Context.php:76
Aimeos\Shop\Base\Config::get("command")
PS C:\Users\conta\Desktop\PARANHOS\laravel-auth>
Re: must be of the type array
Post by aimeos » 21 Nov 2020, 10:04
Look at the ./config/shop.php and the config files in your own extension. In one of your own config files, maybe no array is returned.
mateusanjosv
Post by mateusanjosv » 21 Nov 2020, 20:38
solved, thanks
