order history
GülsümAkça
order history
Post by GülsümAkça » 17 Dec 2020, 09:51
I want to get the delivery status and total order price in the templates/account/history/list-body-standard.php file. Currently there is a function related to the delivery status, but it doesnt work. how can I do that.
Re: order history
Post by aimeos » 18 Dec 2020, 08:39
The delivery status is available using
$orderItem->getStatusDelivery()
beginning from here: https://github.com/aimeos/ai-client-htm ... d.php#L100
The order total value is not because the order base object is only availabe in the order-body-standard.php template. To add that data to the list template, you have to create a decorator that implements addData(), calls addData() of the underlying object and uses the order items assigned to the view (https://github.com/aimeos/ai-client-htm ... d.php#L218) to fetch the order base items from the storage.
You can find documentation for decorators here:
https://aimeos.org/docs/latest/frontend ... omponents/
GülsümAkça
Re: order history
Post by GülsümAkça » 25 Dec 2020, 07:33
Thank you for your answer. Does the getDeliveryStatus() function work? even if the delivery status is updated, it doesnt appear in the list order section on aimeos demo site
Re: order history
Post by aimeos » 29 Dec 2020, 08:40
In the account/history list template, the delivery status is only displayed if the delivery date is also set:
https://github.com/aimeos/ai-client-htm ... d.php#L159
