Missing route parameter error
zaheer
Post by zaheer » 13 Jan 2021, 10:21
In my multi shop multi language installation. I am getting this error after I change the routes in shop.php
Missing required parameter for [Route: aimeos_shop_jsonapi_options] [URI: {site}/{locale}/jsonapi/{resource?}] [Missing parameter: locale].
I am using :
Laravel 8
PHP 7.4
Aimeos 2020.10
My Controller code is :
    public function indexAction(Request $request)
        foreach( config( 'shop.page.catalog-detail' ) as $name )
            $params['aiheader'][$name] = Shop::get( $name )->getHeader();
            $params['aibody'][$name] = Shop::get( $name )->getBody();
        // do some more stuff
        return \View::make('welcome', $params);
and blade file is (unnecessary part removed):
@extends('shop::base')
@section('aimeos_header')
    <?= $aiheader['basket/mini'] ?>
    <?= $aiheader['locale/select'] ?>
<link href="//maxcdn.bootstrapcdn.com/font-awesome/4.1.0/css/font-awesome.min.css" rel="stylesheet">
@stop
@section('aimeos_head')
<?= $aibody['locale/select'] ?>
<?= $aibody['basket/mini'] ?>
@stop
shop.php file :
<?php
return [
	'apc_enabled' => false, // enable for maximum performance if APCu is availalbe
	'apc_prefix' => 'laravel:', // prefix for caching config and translation in APCu
	'pcntl_max' => 4, // maximum number of parallel command line processes when starting jobs
	'routes' => [
		// Docs: https://aimeos.org/docs/Laravel/Custom_routes
		// Multi-sites: https://aimeos.org/docs/Laravel/Configure_multiple_shops
		// 'admin' => ['prefix' => 'admin', 'middleware' => ['web']],
		// 'jqadm' => ['prefix' => 'admin/{site}/jqadm', 'middleware' => ['web', 'auth']],
		// 'jsonadm' => ['prefix' => 'admin/{site}/jsonadm', 'middleware' => ['web', 'auth']],
		 'jsonapi' => ['prefix' => '{site}/{locale}/jsonapi', 'middleware' => ['web', 'api']],
		 'account' => ['prefix' => '{site}/{locale}/profile', 'middleware' => ['web', 'auth']],
		 'default' => ['prefix' => '{site}/{locale}/shop', 'middleware' => ['web']],
		// 'update' => [],
	'page' => [
		// Docs: https://aimeos.org/docs/Laravel/Adapt_pages
		// Hint: catalog/filter is also available as single 'catalog/search', 'catalog/tree', 'catalog/price', 'catalog/supplier' and 'catalog/attribute'
		'account-index' => [ 'account/profile','account/review','account/subscription','account/history','account/favorite','account/watch','basket/mini','catalog/session' ],
		'basket-index' => [ 'basket/bulk', 'basket/standard','basket/related' ],
		'catalog-count' => [ 'catalog/count' ],
		'catalog-detail' => [ 'basket/mini','locale/select','catalog/stage','catalog/detail','catalog/session','catalog/filter','catalog/lists' ],
		'catalog-home' => [ 'basket/mini','catalog/search','catalog/tree','catalog/home' ],
		'catalog-list' => [ 'basket/mini','catalog/filter','catalog/lists' ],
		'catalog-stock' => [ 'catalog/stock' ],
		'catalog-suggest' => [ 'catalog/suggest' ],
		'catalog-tree' => [ 'basket/mini','catalog/filter','catalog/stage','catalog/lists' ],
		'checkout-confirm' => [ 'checkout/confirm' ],
		'checkout-index' => [ 'checkout/standard' ],
		'checkout-update' => [ 'checkout/update' ],
	'admin' => [],
	'client' => [
		'html' => [
			'locale' => [
				'select' => [
					'currency' => [
						'param-name' => 'currency',
					'language' => [
						'param-name' => 'locale',
			'basket' => [
				'cache' => [
					// 'enable' => false, // Disable basket content caching for development
			'common' => [
				'template' => [
					// 'baseurl' => 'packages/aimeos/shop/themes/elegance',
	'controller' => [
	'i18n' => [
	'madmin' => [
		'cache' => [
			'manager' => [
				'name' => 'None', // Disable caching for development
		'log' => [
			'manager' => [
				'standard' => [
					// 'loglevel' => 7, // Enable debug logging into madmin_log table
	'command' => [
	'frontend' => [
	'backend' => [
What extra needs to be done. Please help.
Re: Missing route parameter error
Post by aimeos » 13 Jan 2021, 10:37
You've configured the "jsonapi" route to require a "locale" parameter which leads to the error when the locale parameter isn't present:
You should remove it from the route and add it as "?locale=en" to the URL if necessary.
zaheer
Post by zaheer » 13 Jan 2021, 11:05
Thanks for the reply.
My site is multilingual. Removing locale from jsonapi does solve the issue for main page, but shop pages are not working.
Leaving locale intact and adding ?locale=en works. But is there some other way because I need to display home page from main url.
In local machine :
http://localhost:8000 generates error
http://localhost:8000/?locale=en works
Problem is in this controller code :
How can I add locale parameter in this code ?
zaheer
Post by zaheer » 13 Jan 2021, 11:11
Sorry for irrelevant question.
I think it was related to Laravel not Aimeos
Solved it by adding this to controller :
$request->request->add(['locale' => 'en']);
Is this the right way ?
