Creating filter with value of key as column name
dheeraj
Post by dheeraj » 27 Jan 2021, 07:23
Laravel : 8.12
Aimeos : 2020.10
PHP Version : 7.4.13
Environment : Windows
I have added a new column to mshop_stock table with name 'threshold'.
Now i need to get all stock items whose stocklevel value is less than or equal to the value in its corresponding threshold value.
I cannot find how to create such filter. add() method of filter object only adds 'column key' , 'operator' and 'fixed value' for the column key. But in our case, 'fixed value' is determined by the value in the 'threshold' column of corresponding row in mshop_stock table.
I cannot find anything related to this in documentation.
I created an SQL query manually and executed it in the table mshop_stock and its working.
SELECT * FROM mshop_stock WHERE stocklevel <= threshold;
How can i create such filter for stock items ??? :roll:
Re: Creating filter with value of key as column name
Post by aimeos » 29 Jan 2021, 08:45
Like you've already noticed, it's not possible to use a column name as argument for conditions, only fixed values. This would be only possible in SQL but e.g. not in other storages like ElasticSearch. To support all type of storages, you have to add a "search function" like this:
https://github.com/aimeos/aimeos-core/b ... #L175-L183
It can contain storage (SQL) specific code that can be part of a query. In your case, something like
'stock:low' => array(
	'code' => 'stock:low()',
	'internalcode' => '(msto."stocklevel" < msto."threshold)"',
	'label' => 'Low stock levels',
	'type' => 'boolean',
	'internaltype' => 'boolean',
	'public' => false,
should work. In your code, you add this condition by using:
$filter->add( $filter->make( 'stock:low', [] ), '==', true )
This will create a MySQL query like:
... WHERE (msto."stocklevel" < msto."threshold) = 1
And in PostgreSQL it will be:
... WHERE (msto."stocklevel" < msto."threshold) = true
Because the "internalcode" is always compared to some value, it must return something that is comparable. In this case it's a boolean true/false value but in other cases, you need to add a subquery in the "internalcode" to match that need and compare against a (not) NULL value.
More information for using search functions is described here:
https://aimeos.org/docs/latest/infrastr ... -functions
