"Error saving data" issue
eartisan-uk
Post by eartisan-uk » 02 Feb 2021, 09:33
Hello there,
One of my developers is experiencing this issue where they are unable to make any changes within the admin dashboard as they are getting the message "Error saving data", every time they try it. They've tried on two different Aimeos instances installed on completely different servers on different IP addresses. They are using Ubuntu (environment details are given below), but they've tried using Anydesk to log into a remote Windows machine which surprisingly gave the same error. I managed to log in to both instances using the same login credentials and managed to perform all tasks without any issues so I wonder if this is an IP related issue. I have attached a couple of screenshots to this. Any input on this is highly appreciated.
Thanks and regards,
Pradeep
Server
Aimeos: 2010.10
Laravel Framework 6.20.15
PHP: 7.4.8
Client
Ubuntu 16.04 (64 bit)
Firefox: 84.0.2 (64-bit)
Chrome: 88.0.4324.96 (Official Build) (64-bit)
Re: "Error saving data" issue
Post by aimeos » 04 Feb 2021, 20:39
You can see the logged errors in the Admin backend -> Log panel (extended left navbar)
