Can I create multi stores with different themes?
ArthurHenrique
Post by ArthurHenrique » 09 Feb 2021, 17:19
Hi, I need to know if I can create only one website (one domain), with multi stores, and the stores will have its own theme.
I know how to create multi stores (sites) but I don´t know if is possible that wich store has his own theme.
Thanks, Arthur.
Enviroment:
Windows 10
PHP = 7.2
Laravel = 6.0
Aimeos = 2020.10
Re: Can I create multi stores with different themes?
Post by aimeos » 09 Feb 2021, 17:42
There's no "official" support for a theme per site as it's not fully functional and not very conveniant yet.
You can't assign a theme including CSS/JS files to a site yet because it's configurable but not per site:
https://github.com/aimeos/aimeos-larave ... .blade.php
You can add settings for the "option/value" table for each site in the Locale -> Site panel which can also include settings for different template files but it's not very conveniant.
Help to improve this is very welcome! :-)
