Error: Cannot use a scalar value as an array
alesconti
Post by alesconti » 27 Feb 2021, 12:12
I have now website on nginx and php 8.0 environment.
I used composer to install complete package without problems.
Now when i'm try to open demo product a receive the following error:
Symfony\Component\Debug\Exception\FatalThrowableError
Aimeos\MShop\Index\Manager\Attribute\Standard::__construct
vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Index/Manager/Attribute/Standard.php:79
Do you know why ?
Re: Error: Cannot use a scalar value as an array
Post by aimeos » 27 Feb 2021, 12:53
The line seems to be uncritical:
https://github.com/aimeos/aimeos-core/b ... rd.php#L79
In the class it's also an array:
https://github.com/aimeos/aimeos-core/b ... hp#L34-L47
This seems like a bug in PHP 8 and when using PHP 8.0.2, I currently get a segmentation fault so that PHP version doesn't seem to work at all for Laravel/Aimeos.
alesconti
Post by alesconti » 27 Feb 2021, 13:25
Downgraded my server to php 7.4
Thanks for the support !
