Running CronJobs In Production
quadri_folo
Post by quadri_folo » 17 Mar 2021, 00:35
Laravel Version: ^6.20.12"
PHP Version 7.2
Mac OS
Aimeos Verison 2020
Host Hostinger
Is it possible to run cronjobs from a php file instead of running the script ? I
Re: Running CronJobs In Production
Post by aimeos » 19 Mar 2021, 06:23
The jobs command is implemented here:
https://github.com/aimeos/aimeos-larave ... ommand.php
You can call the command in Laravel like described here:
https://laracasts.com/discuss/channels/ ... controller
But it's not recommended at all because usually, the scripts will be killed after 30sec regardless of the work is done or not.
