Error of csv import
zaheer
Error of csv import
Post by zaheer » 25 Mar 2021, 07:50
I am getting the following error on csv import. The madmin_log table shows no errors and the products does not get imported.
Can anyone shed some light on cause of the error.
php artisan aimeos:jobs product/import/csv dlars
Executing the Aimeos jobs for "dlars"
   TypeError
  Return value of Aimeos\Controller\Common\Product\Import\Csv\Processor\Catalog\Standard::getListItems() must be an instance of Aimeos\Map, array returned
  at E:\ZAH\Laravel\moudhah\ext\ai-controller-jobs\controller\common\src\Controller\Common\Product\Import\Csv\Processor\Catalog\Standard.php:248
    244▕         */
    245▕        protected function getListItems( $prodid, array $types ) : \Aimeos\Map
    246▕        {
    247▕                if( empty( $types ) ) {
  ➜ 248▕                        return [];
    249▕                }
    250▕
    251▕                $manager = \Aimeos\MShop::create( $this->getContext(), 'catalog/lists' );
    252▕                $search = $manager->createSearch()->setSlice( 0, 0x7FFFFFFF );
  1   E:\ZAH\Laravel\moudhah\ext\ai-controller-jobs\controller\common\src\Controller\Common\Product\Import\Csv\Processor\Catalog\Standard.php:135
      Aimeos\Controller\Common\Product\Import\Csv\Processor\Catalog\Standard::getListItems("345", [])
  2   E:\ZAH\Laravel\moudhah\ext\ai-controller-jobs\controller\common\src\Controller\Common\Product\Import\Csv\Processor\Stock\Standard.php:75
      Aimeos\Controller\Common\Product\Import\Csv\Processor\Catalog\Standard::process(Object(Aimeos\MShop\Product\Item\Standard))
Re: Error of csv import
Post by aimeos » 28 Mar 2021, 06:58
There are two possible sources for the problem:
1.) You've configured "controller/common/product/import/csv/processor/catalog/listtypes" to be an empty array
2.) You've deleted the catalog list types in the backend or they haven't been imported during initial setup
In the later case, make sure that the Types > Catalog list panel in the admin backend if it contains entries with domain "product" and code "default" and "promotion". If they are not there, run
php artisan aimeos:setup
