After Payment Decorator with PaypalExpress
forons
Post by forons » 29 Mar 2021, 14:41
Hi all,
I am using Aimeos 2020.10.6 with PHP 7.3. The system is pretty good!
The only issue I found up to now is to add a decorator that performs some operations after the payment (done through PaypalExpress).
I found a related topic laravel-package-f18/hook-into-order-com ... t2687.html, however, even following the procedure explained there I ended up with having problems.
Basically, I redefined the updatedSync function in this way:
public function updateSync(
        \Psr\Http\Message\ServerRequestInterface $request,
        \Aimeos\MShop\Order\Item\Iface $order
    ): \Aimeos\MShop\Order\Item\Iface {
        if ($paymentStatus == \Aimeos\MShop\Order\Item\Base::PAY_RECEIVED) {
           send_email_to_user_and_update_db
        return $order;
I have a specific use case that doesn't allow me to use the cronjob function provided by Aimeos.
However, the status there is always pending.
I also tried to move the logic in the updatePush function, but the result is exactly the same.
Instead, if I remove the decorator I created, the payment succeed.
Can someone please help me? What am I doing wrong?
Looking forward for a reply, thanks for the time and help!
Re: After Payment Decorator with PaypalExpress
Post by aimeos » 31 Mar 2021, 17:03
If you write a decorator and want the underlying object to do its job, you need to call
$this->getProvider()->updateSync($request, $orderItem);
first. Thus, your code should look like:
    ) : \Aimeos\MShop\Order\Item\Iface
	$order = $this->getProvider()->updateSync($request, $order);
        if ($order->getPaymentStatus() == \Aimeos\MShop\Order\Item\Base::PAY_RECEIVED) {
        return $order;
forons
Post by forons » 01 Apr 2021, 16:57
Ok, thanks a lot for the reply. That solved the issue and is exactly what I was looking for!
