about stock level
GülsümAkça
about stock level
Post by GülsümAkça » 29 Mar 2021, 22:57
I want to get stock level of the product in the catalog/detail/body-standard.php, how can i do that
thank you :)
Re: about stock level
Post by aimeos » 31 Mar 2021, 17:05
Just add "stock" to this configuration:
https://aimeos.org/docs/2020.x/config/c ... l/#domains
Then, you can get the stock items using:
$stockItems = $this->detailProductItem->getStockItems()
