Extend php artisan aimeos:setup <site code> [<template site>]
Kevin1596
Post by Kevin1596 » 12 Apr 2021, 07:45
Thanks you for your all your support,
Currently, I am trying to extend the aimeos:setup jobs
My requirements are :
- set up new template similar to 'default' template with some predefined data such as locales products
- clone new shop by copy the new template default data to
Is there any convenient way to extend the setup job?
A suggestion is:
- Could we extend the set up task to have ability to clone all data from an existing shop to new-shop?
Re: Extend php artisan aimeos:setup <site code> [<template site>]
Post by aimeos » 14 Apr 2021, 08:25
Yes, the setup tasks are the right way to go to add default data to new sites or copy from existing sites. Please have a look at the existing ones for reference:
https://github.com/aimeos/aimeos-core/t ... up/default
unknow76616
Post by unknow76616 » 21 Apr 2024, 08:24
The link is no longer working (404 - page not found). Is there an alternative link?
Post by aimeos » 21 Apr 2024, 10:13
