Change the database of a project aimeos
ArthurHenrique
Post by ArthurHenrique » 16 Apr 2021, 13:47
Hi, I need help to change the database of my project aimeos.
I have no idea how to do that, I had created a new database and had changed the parameter (DB_DATABASE=) of the .env arquive, so I've try using php artisan migrate but its not worked, what I can do to have all the extructure that I had? Sorry about my english, its not so good.
Enviroment:
Windows 10
PHP = 7.2
Laravel = 6.0
Aimeos = 2020.10
Re: Change the database of a project aimeos
Post by aimeos » 18 Apr 2021, 08:40
You have to run this command to create the Aimeos database tables:
php artisan aimeos:setup
mahmoud
Post by mahmoud » 18 Apr 2021, 12:17
  • Change the database name in .env
  • change the name of the database in the file config/shop.php
write
php artisan config:cache ;php artisan cache:clear ; php artisan aimeos:clear
and try the command :
 php ./artisan aimeos:setup
php ./artisan route:clear
php ./artisan view:clear
php ./artisan aimeos:clear
