Get the list of properties in media
AmzoooJibal
Post by AmzoooJibal » 22 Apr 2021, 10:43
i need to get the list of properties in media domaine inside advanced section in catalog.
I have a catalog with list of media for the catalog i can do:
$homeTree->getConfig()
Then to get the media:
($mediaItems = $this->homeTree->getRefItems('media', 'stage', 'default'))->isEmpty())
Now for each mediaItem how i can get the config properties ?
AmzoooJibal
Re: Get the list of properties in media
Post by AmzoooJibal » 22 Apr 2021, 11:12
Is Like this:
   $this->homeTree->getListItem('media','default',$mediaItem->getId())->getConfig();
Post by aimeos » 24 Apr 2021, 09:31
Media items doesn't have a configuration but you can attach property items to them (type, language, value pairs) in the admin backend. Then, you can get them using:
foreach($this->homeTree->getRefItems('media','default') as $mediaItem) {
	print_r($mediaItem->getProperties('<type of the property>'));
AmzoooJibal
Post by AmzoooJibal » 27 Apr 2021, 17:00
Thank you for you response.
It's a little complicated aimeos object.
With laravel Eloquent its easy to get child from parent even if the relation isnt loaded initially.
my question in home page i have a product object (Aimeos\MShop\Product\Item\Standard) and i need to access the variant product from this object how i can do that ?
i have tried but list empty:
$product->getRefItems('attribute', null, 'variant')
Post by aimeos » 01 May 2021, 16:09
AmzoooJibal wrote: 27 Apr 2021, 17:00 It's a little complicated aimeos object.
That's one of the reasons we don't use Eloquent or something that offers that feature because this will load the related records on request. This turns into a performance nightmare if it's actually used because e.g. for a product list view with 100 products, 201 queries will be executed (one for all products, 100 for the relations and 100 for the attribute records) and people are complaining why it's so slow.
Contrary, in Aimeos you need to say upfront what should be loaded so there will be only three queries executed (one for the product, one for the relation and one for the attribute records).
AmzoooJibal wrote: 27 Apr 2021, 17:00 my question in home page i have a product object (Aimeos\MShop\Product\Item\Standard) and i need to access the variant product from this object how i can do that ?
Your code is correct but you need to configure that the product attributes should be loaded in the catalog/home component:
https://aimeos.org/docs/latest/config/c ... e/#domains
