How to overwrite js for other extensions ?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 29 Apr 2021, 17:12
Hi community!
I want to customize something in grapesjs (I want in assetManager when adding the image to canvas to get the alt attribute inserted from server, but this I even don't suppose that someone has the solution), so for that I want to make own fixes, compile and include the new grapesjs. But how can I disable the included js in the ai-cms-grapesjs extension in file manifest.jsb2 ?
Thank you very much !
Re: How to overwrite js for other extensions ?
Post by aimeos » 01 May 2021, 15:51
You can't disable adding the GrapesJS Javascript code from the ai-cms-grapesjs extension but in Javascript and GrapesJS, you can overwrite objects and functions. You need to get a bit used to how GrapesJS and Javascript does things first. A good starting point for customizing GrapesJS is the custom.js file in the extension:
https://github.com/aimeos/ai-cms-grapes ... /custom.js
For overwriting the image handling, especially these lines should be helpful:
https://github.com/aimeos/ai-cms-grapes ... #L514-L519
