Laravel Aimeos\MShop\Exception : Unable to call method "insertItem"
limack
Post by limack » 06 May 2021, 13:06
I have been facing this error for some time when trying to create a "merchant" account from the register form. How can I fix this?
Thanks!
Re: Laravel Aimeos\MShop\Exception : Unable to call method "insertItem"
Post by aimeos » 06 May 2021, 13:14
Does it work if you replace "insertItem()" by "insert" here in your application:
https://github.com/aimeos/aimeos/blob/1 ... er.php#L85
limack
Post by limack » 06 May 2021, 13:27
Yes, it works.Thanks you!
