Selection / Variant product add to cart
ttyy
Post by ttyy » 07 May 2021, 09:20
I have a general question about "Add to Cart" functionality on the variant product type.
facet search and product page has "add to cart" button, but unless you'll select an option for the particular variation of the product you are getting - "No unique article found for selected attributes and product ID "***" " error message.
Is there a way to have a default value for the variation option?
Re: Selection / Variant product add to cart
Post by aimeos » 07 May 2021, 11:22
Not by default but you can overwrite the "Select" basket frontend decorator and use the first returned variant:
https://github.com/aimeos/ai-controller ... #L194-L198
ttyy
Post by ttyy » 12 May 2021, 10:10
Great thank you for help!
