Function to get file from store
AmzoooJibal
Post by AmzoooJibal » 01 Jun 2021, 11:10
hello,
i have created a helper file in laravel project with this function that return the file from store like this:
function file_from_store($path): string
        $context = app('aimeos.context')->get();
        $config = $context->getConfig();
        $baseUrl = $config->get('resource/fs/baseurl');
        $view = new \Aimeos\MW\View\Standard();
        $view->addHelper('encoder', new \Aimeos\MW\View\Helper\Encoder\Standard($view));
        $view->addHelper('content', new \Aimeos\MW\View\Helper\Content\Standard($view, $baseUrl));
        return $view->encoder()->attr($view->content($baseUrl . '/' . $path));
My question is there a sample why to optimize this function because i have instanciate another object maybe there is already existing one . i have tried like this but not working:
$view = app('aimeos.view')->get();
Re: Function to get file from store
Post by aimeos » 03 Jun 2021, 08:41
Normally, something like this should work:
	return $view->encoder()->attr($view->content$path));
AmzoooJibal
Post by AmzoooJibal » 03 Jun 2021, 18:02
i get an exception with get(), i searched in project i have found view object is instantieted like this:
app( 'aimeos.view' )->create( $context, $tmplPaths, $langid ) ?
Post by aimeos » 04 Jun 2021, 05:56
You are right, in then it's:
function file_from_store( $path ): string
	$langId = $context->getLocale()->getLanguageId();
	$paths = app('aimeos')->get()->getCustomPaths( 'client/html/templates' );
	$view = app('aimeos.view')->create( $context, $paths, $langId );
	return $view->encoder()->attr( $view->content( $path ) );
AmzoooJibal
Post by AmzoooJibal » 04 Jun 2021, 17:05
Yeh Great it work as expected, thank you ;)
