Additional columns of join table during search query
dheeraj
Post by dheeraj » 09 Jun 2021, 07:45
Laravel : 8.12
Aimeos : 2021.04
PHP Version : 7.4.18
Environment : Windows
Hello there.
I am searching for stock items whose mshop_stock.stocklevel is below certain threshold (fixed value) but i also want to perform inner join on the products table ( on mshop_stock.prodid = mshop_product.id ) and include the columns mshop_product.code and mshop_product.label in the result so that i can know which stocks are referring to which product.
How can add these additional columns of join table during search query ??
Re: Additional columns of join table during search query
Post by aimeos » 10 Jun 2021, 11:14
You are asking the almost the same question as in your previous thread regarding that topic and the answer is still the same:
help-f15/how-to-hide-unique-products-in ... t1104.html
