top products by customer, controller, view
columbo
Post by columbo » 23 Jun 2021, 20:06
we'd like to provide in the customer-profiles a list of their 10 most frequently bought products. (quantity of products / customer).
I already found this forum post: laravel-package-f18/how-can-get-bestsel ... t1193.html
$manager = \Aimeos\MShop::create( $context, 'order/base/product' );
$result = $manager->aggregate( $manager->filter(), 'order.base.product.productid', 'order.base.product.quantity', 'sum' );
// find the products which are sold most in $result (product ID is the key, count is the value)
$cntl = \Aimeos\Controller\Frontend::create( $context, 'product' );
$items = $cntl->uses( ['text', 'price', 'media'] )->product( <ids> )->search();
Does "order.base.product.quantity" already takes order-quantities by customers into account or do we have to add the current customer id?
We created a new controller with the code above. Is it possible to use / copy the default Aimeos product list “html client” / view, that is already used for our product catalog? How would the controller look like?
Thank you!
Re: top products by customer, controller, view
Post by aimeos » 26 Jun 2021, 07:06
columbo wrote: 23 Jun 2021, 20:06 Does "order.base.product.quantity" already takes order-quantities by customers into account or do we have to add the current customer id?
As your filter is empty, the result wouldn't be limited to the customer. The customer ID is stored in the mshop_order_base table, so the code must be something like this:
$manager = \Aimeos\MShop::create( $context, 'order/base' );
$filter = $manager->filter()->add( 'customer.id', '==', '<customer id>' );
$result = $manager->aggregate( $filter, 'order.base.product.productid', 'order.base.product.quantity', 'sum' );
columbo wrote: 23 Jun 2021, 20:06 We created a new controller with the code above. Is it possible to use / copy the default Aimeos product list “html client” / view, that is already used for our product catalog? How would the controller look like?
The catalog/list component doesn't contain that code so it won't work that way but you can create a new "account/top10" component and use the templates of the catalog/list component:
https://aimeos.org/docs/latest/frontend ... omponents/
