Implementing JWT for Aimeos/Laravel
Kappa.yahyya
Post by Kappa.yahyya » 09 Jul 2021, 11:43
Hi
I wanted to implement JWT for aimeso , as you know , aimeos is using cookies on its jsonapi.
So i need to remove using cookies and try to add JWT into controllers.
1- First thing is should i use Aimeos as an extension on New and fresh laravel installation or its better to use Aimeos Laravel package?
2- Aimeos Laravel package is using Old laravel , can i update the laravel? Laravel is on 8 version right now.
Re: Implementing JWT for Aimeos/Laravel
Post by aimeos » 09 Jul 2021, 14:30
There are two repositories, the Aimeos Laravel package and the Aimeos distribution.
Use the Aimeos Laravel package and change things there because you can use Laravel 8 with it:
https://github.com/aimeos/aimeos-laravel
