API Versioning Laravel
MohammadShahriariFard
Post by MohammadShahriariFard » 18 Jul 2021, 07:06
Is there a way to versioning aimeos jsonapi & jsonadm?
currently, all web services working this way :
http://localhost:8000/jsonapi/attribute
The way I want is :
http://localhost:8000/jsonapi/v1/product
or :
http://localhost:8000/v1/jsonapi/product
I'm using the latest version of aimeos on Linux OS.
Re: API Versioning Laravel
Post by aimeos » 19 Jul 2021, 06:13
You can change the prefix for the jsonapi route in your ./config/shop.php:
https://github.com/aimeos/aimeos-larave ... op.php#L16
Post by MohammadShahriariFard » 19 Jul 2021, 11:43
aimeos wrote: 19 Jul 2021, 06:13 You can change the prefix for the jsonapi route in your ./config/shop.php:
That was the easiest solution But it is not efficient at least in this case.
Because we may need several different versions, such as V1, V2, V3 in the future...
Should we create a separate extension for each version?
Should we add {version} parameter to the core route like below?
			Route::match( array( 'GET' ), '{version}/{resource}', array(
			'as' => 'aimeos_shop_jsonapi_get',
			'uses' => 'Aimeos\Shop\Controller\JsonapiController@getAction'
		) )->where( ['site' => '[A-Za-z0-9\.\-]+'] );
Instead of :
			Route::match( array( 'GET' ), '{resource}', array(
Given these conditions, what will be the structure of the directories and classes and route for supporting multi version API?
Considering that we need all versions because different parts of the project interact with all versions and we can not just have one version.
Post by aimeos » 19 Jul 2021, 20:22
We don't change the JSON REST API in an incompatible way and therefore, we don't need versioning.
If you want to have different versions, you can add routes for each version pointing to different controller actions where you can use different implementations.
