Overwriting Translations not working in PHPStorm
daveamweb
Post by daveamweb » 03 Aug 2021, 14:28
Hi everyone,
First I am new to Laravel and PHPstorm so I might be missing something obvious to everyone, but I am not seeing it.
I have Aimeos demo running and wanted to change the translation for Basket to Shopping cart as outlined here: https://aimeos.org/docs/latest/laravel/ ... anslations
In PHPStorm I am editing the shop.php file located in under project -> config -> Shop.php
The code I am using is copied from the documentation and is shown below.
'i18n' => [
        'en_US' => [
            'client' => [
                'basket' => ['Shopping cart'],
I am working on a Mac M1 (chip if it matters) with a Laravel environment built from Valet. I am running PHP 7.4, MySQL 8 and everything else is the latest.
Is there some cache that needs to be flushed or something? I have restarted NGINX and the valet framework to no success.
Thanks for helping.
Re: Overwriting Translations not working in PHPStorm
Post by aimeos » 03 Aug 2021, 15:53
Most likely, you don't have "en_US" in the Locale > Locale list of the admin backend and if yes it's not the one that's used by default. After installing Aimeos, "en" language is default and to change the translation for that language use:
'i18n' => [
        'en' => [
            'client' => [
daveamweb
Post by daveamweb » 03 Aug 2021, 19:23
Thank you!
I did as you suggested, but unfortunately I am still seeing no change the the basket text.
After making the change do I need to flush any caches? I even restarted dnsmasq, NGINX and PHP just in case.
The whole demo site is showing in English, so I am thinking the language must be set to English too. I can login to the demo and the demo site runs just fine. Not sure what else I can add here that would be insightful.
Thank you
Post by aimeos » 04 Aug 2021, 05:58
You need to clear the content cache using:
php artisan aimeos:clear
Furthermore, change something in the basket so it's refreshed.
greg1099etc
Post by greg1099etc » 04 Aug 2021, 21:19
Laravel v8.52.0 (PHP v7.4.22); Aimeos 2021.07.04; Mac OSX 11.4
I am having the same issue (because we're working on the same project.
I have tried:
php artisan cache:clear
brew services restart redis
... added a product to the 'basket', removed the product, and still getting the same results.
Post by aimeos » 05 Aug 2021, 05:47
The strings are case sensitive. Can you try instead:
'i18n' => [
        'en' => [
            'client' => [
                'Basket' => ['Shopping cart'],
This will change the name of the header in the offscreen basket if you click on the basket item.
greg1099etc
Post by greg1099etc » 05 Aug 2021, 12:45
That worked!
And so you're aware, the https://aimeos.org/docs/2021.x/laravel/ ... anslations does not reference case-sensitivty.
Post by aimeos » 05 Aug 2021, 14:48
We've added a hint about case sensitivity now
