Unable to save new product
mgrifa
Post by mgrifa » 06 Aug 2021, 10:38
i'm starting using Aimeos but i can't figure out why my custom product import is not working and doesn't give any error.
I created the following job controller:
class Standard extends Base implements Iface
    public function getName() : string
        return $this->getContext()->getI18n()->dt( 'controller/jobs', 'Product import via json');
    public function getDescription() : string
        return $this->getContext()->getI18n()->dt( 'controller/jobs', 'Import all products from json');
    public function run()
        $manager = MShop::create($context,'product');
        $logger = $context->getLogger();
        try {
            $item = $manager->create([
                    'product.code' => 'TEST',
                    'product.label' => 'TEST PRODUCT',
                    'product.type' => "default",
                    'product.status' => 1,
                    'price.currencyid' => "EUR",
                    'price.quantity' => 1,
                    'price.value' => 1.20,
                    'price.taxrate' => 22.0,
                    'catalog.code' => "F1",
                $item = $manager->save($item, true);
                $logger->log("Id: " . $item->getId());
        catch (\Throwable $e) {
            $manager->rollback();
            $logger->log('Product import error: ' . $e->getMessage() . "\n" . $e->getTraceAsString());
Laravel Version: 6.20.31
Aimeos Version: 2021.07.4
Php Version: 8.0.9
Re: Unable to save new product
Post by aimeos » 07 Aug 2021, 10:21
First, you have to create a factory class because for "product/import" there's no default one available (only for "product/import/csv" and "product/import/xml"):
https://aimeos.org/docs/latest/cronjobs ... r/#factory
Furthermore, the namespace is missing in your file:
namespace Aimeos\Controller\Jobs\Product\Import;
        try {
Execute the importer using:
php artisan aimeos:jobs product/import
