missing translations
GülsümAkça
Post by GülsümAkça » 17 Aug 2021, 10:28
There are translation missing in the file \vendor\aimeos\aimeos-core\lib\mshoplib\i18n\ru.po. How can I add a translation without modifying the core file? aimeos laravel 2020.10.08 version
Re: missing translations
Post by aimeos » 18 Aug 2021, 06:50
It's documented here:
https://aimeos.org/docs/latest/developer/translations/
As it's easier for us to do that, we will create a new 2020.10 release tomorrow including the latest translations for you.
GülsümAkça
Post by GülsümAkça » 18 Aug 2021, 09:12
Thank you! :))
GülsümAkça
Post by GülsümAkça » 18 Aug 2021, 09:24
Warning message appears in English when I enter the wrong birthday on the checkout page even though I added a translation. How can I fix it without changing the core file?
Images with the error:
https://prnt.sc/1q9xvov
https://prnt.sc/1q9y6rb
Post by aimeos » 18 Aug 2021, 12:35
This is a good example of a message that wasn't translatable up to now because it contained a placeholder (the actual value) which was replaced before translation. We've now changed the strings to avoid placeholders (currently available in .x-dev versions) but you need add new translations in Transifex too for the new strings.
