What means <!-- in templates page
AmzoooJibal
Post by AmzoooJibal » 18 Aug 2021, 13:02
what is the role of <!-- in templates pages ? for example in the count collection of supplier i have this javascript code:
<?php $this->block()->start( 'catalog/count/supplier' ) ?>
var supplierCounts = <?= $this->get( 'supplierCountList', map() )->toJson( JSON_FORCE_OBJECT ) ?>;
$( ".catalog-filter-supplier .supplier-lists li.attr-item" ).each( function( index, item ) {
	$(item).append( function() {
		var itemId = $(this).data( "id" );
		if( supplierCounts[itemId] ) {
			var node = document.createElement( 'span' );
			node.appendChild( document.createTextNode( supplierCounts[itemId] ) );
			$(node).addClass( 'attr-count' );
			return node;
		$(this).addClass( 'disabled' );
<?php $this->block()->stop() ?>
where and when this code are executed ? and what is the role of <!-- in template page ?
AmzoooJibal
Re: What means <!-- in templates page
Post by AmzoooJibal » 18 Aug 2021, 16:20
for the first question, the supplier count is executed by the javascript in the header of filter :
<?php if( ( $url = $this->get( 'filterCountUrl' ) ) != null ) : ?>
	<script defer src="<?= $enc->attr( $url ) ?>"></script>
<?php endif ?>
this filter get all count html (in this case javascript).
I have just one more question is there any role of <!-- ? i can delete them ?
Post by aimeos » 19 Aug 2021, 05:44
This is a protection that the browser doesn't interpret the Javascript code as HTML. Just leave it there.
