Admin Dashboard / Sales / Orders / [Edit Invoice] Error!
lebanon_dd
Post by lebanon_dd » 23 Aug 2021, 05:05
Hello Guys,
I search around to find a solution, with no success.
Logging into Admin Dashboard, going to the "Invoices" or "Sales".
I edited an invoice, and tried to save, but an error in "Billing Address" ' country dropdown.
Billing Address' country dropdown is empty with "Please select" without countries list.
I can not select the country, although, checking the User info, billing country was well added.
Please help.
Re: Admin Dashboard / Sales / Orders / [Edit Invoice] Error!
Post by aimeos » 23 Aug 2021, 05:59
Which Aimeos version are you using? The problem is fixed in the latest one.
lebanon_dd
Post by lebanon_dd » 23 Aug 2021, 06:17
Can you remind me where I can find the Version I am using, please.
Post by aimeos » 23 Aug 2021, 06:34
composer show
lebanon_dd
Post by lebanon_dd » 23 Aug 2021, 07:25
aimeos/aimeos-laravel 2021.07.4
lebanon_dd
Post by lebanon_dd » 25 Aug 2021, 03:47
aimeos/aimeos-laravel 2021.07.4 is the latest version, right?
Post by aimeos » 25 Aug 2021, 05:05
Yes, but Aimeos consists of several packages including the package for the admin backend. Please run "composer up" and check if the problem is still there.
lebanon_dd
Post by lebanon_dd » 25 Aug 2021, 14:00
Thank you very much.
Problem solved.
I appreciate your quick feed back.
