Is Aimeos an SPA?
Is Aimeos an SPA?
Hi! Since Aimeos is lightning fast, is it considered as a single page application? AKA an SPA?
Re: Is Aimeos an SPA?
No, the HTML frontend doesn't use a PWA, the code is only highly optimized.
It's a common mistake to think that PWAs are fast by default. In fact, they are only fast if their output is prerendered by a NodeJS server. If not, they are painfully slow, at least at the first request.
Ah okay, thanks for the explanation!
