Product Filter (Currency Reset Issue)
Rafeel
Post by Rafeel » 21 Sep 2021, 07:48
Frontend - While apply the product filter on shop page, results loading with the default currency instead of the selected one.
Re: Product Filter (Currency Reset Issue)
Post by aimeos » 21 Sep 2021, 14:01
Did you set up your routes according to:
https://aimeos.org/docs/latest/laravel/ ... ze/#routes
In the current dev-master branch there's an improvement that prevents Laravel from throwing away the currency GET parameter if it's not part of the route.
Rafeel
Post by Rafeel » 22 Sep 2021, 07:40
Thank you.
Added the below routes with shop.php
'default' => ['prefix' => 'shop/{currency}', 'middleware' => ['web'] ],
Now filter is working as expected. But homepage getting the below error while try to access with direct domain (Ex: www.example.com). Earlier the same loaded with default currency.
Missing required parameters for [Route: aimeos_shop_list] [URI: {currency}].
Anything wrong with this one - 'default' => ['prefix' => 'shop/{currency}', 'middleware' => ['web'] ],
Post by aimeos » 23 Sep 2021, 13:56
As currency isn't an optional parameter, you have to add a route in your ./routes/web.php file that redirects to the default currency like:
    Route::get('/', function () {
        return redirect('/EUR');
Rafeel
Post by Rafeel » 24 Sep 2021, 11:05
Thank you. Issue got resolved
