Display custom field in user profile and mail
columbo
Post by columbo » 23 Sep 2021, 20:33
I added a custom field to customer's address using a Address\Decorator:
namespace Aimeos\MShop\Customer\Manager\Address\Decorator;
class Myproject extends \Aimeos\MShop\Common\Manager\Decorator\Base
    private $attr = [
        'custid' => [
            'code' => 'custid',
            'internalcode' => 'lvuad."custid"',
            'label' => 'Kundennummer',
            'type' => 'string',
            'internaltype' => \Aimeos\MW\DB\Statement\Base::PARAM_STR,
    public function getSaveAttributes() : array
        return parent::getSaveAttributes() + $this->createAttributes( $this->attr );
    public function getSearchAttributes( bool $sub = true ) : array
        return parent::getSearchAttributes( $sub ) + $this->createAttributes( $this->attr );
The field is displayed in the customers profile (backend) and also stored in DB.
How can I display the field value eg. on the checkout confirm page or in the payment mail?
tried with $addr->get( 'custid' ); but without success:
<?php foreach( $this->summaryBasket->getAddress( 'custid' ) as $addr ) : ?>
    <?= $addr->getCompany();?>
    <?= $addr->getPostal();?>
    <?= $addr->getCity();?><br>
    <?= $addr->get( 'custid' ); ?>
<?php endforeach; ?>
thank you.
Re: Display custom field in user profile and mail
Post by aimeos » 24 Sep 2021, 07:03
This doesn't return anything:
You have to use:
$this->summaryBasket->getAddress( 'delivery' )
// or
$this->summaryBasket->getAddress( 'payment' )
columbo
Post by columbo » 24 Sep 2021, 07:19
sorry, copy/paste mistake, I already have: $this->summaryBasket->getAddress( 'delivery' )
how can I print out the value of the custom field custid?
<?php foreach( $this->summaryBasket->getAddress( 'delivery' ) as $addr ) : ?>
does not return any value
Post by aimeos » 26 Sep 2021, 10:17
Should be working. You can use print_r() to display the content of the address item object.
columbo
Post by columbo » 27 Sep 2021, 20:40
Custid is stored in DB table "users_address" successfully, but not part of the address item object displayed with:
<?= print_r( $this->summaryBasket->getAddress( 'delivery' ) ) ; ?>
Do I have an error in my decorator?
<?php
// add custid-field to each customer address
    private $attr = [
        'custid' => [
            'code' => 'custid',
            'label' => 'CustId Address',
            'type' => 'string',
Post by aimeos » 28 Sep 2021, 08:30
Implementation looks fine and your decorator is used. Otherwise, the values won't be stored.
Did you change the SQL for "search" in user_address? What's the current SQL statement?
You can check if you configure:
madmin/log/manager/loglevel = 7
columbo
Post by columbo » 28 Sep 2021, 20:57
yes, custid is part of the select query.
SELECT lvuad."custid",
lvuad."id" AS "customer.address.id", lvuad."parentid" AS "customer.address.parentid",
lvuad."company" AS "customer.address.company", lvuad."vatid" AS "customer.address.vatid",
lvuad."salutation" AS "customer.address.salutation", lvuad."title" AS "customer.address.title",
lvuad."firstname" AS "customer.address.firstname", lvuad."lastname" AS "customer.address.lastname",
lvuad."address1" AS "customer.address.address1", lvuad."address2" AS "customer.address.address2",
lvuad."address3" AS "customer.address.address3", lvuad."postal" AS "customer.address.postal",
lvuad."city" AS "customer.address.city", lvuad."state" AS "customer.address.state",
lvuad."countryid" AS "customer.address.countryid", lvuad."langid" AS "customer.address.languageid",
lvuad."telephone" AS "customer.address.telephone", lvuad."email" AS "customer.address.email",
lvuad."telefax" AS "customer.address.telefax", lvuad."website" AS "customer.address.website",
lvuad."longitude" AS "customer.address.longitude", lvuad."latitude" AS "customer.address.latitude",
lvuad."pos" AS "customer.address.position", lvuad."mtime" AS "customer.address.mtime",
lvuad."editor" AS "customer.address.editor", lvuad."ctime" AS "customer.address.ctime",
lvuad."siteid" AS "customer.address.siteid", lvuad."birthday" AS "customer.address.birthday"
FROM "users_address" AS lvuad
WHERE ( ( lvuad."siteid" = '' OR lvuad."siteid" = '1.' ) AND lvuad."parentid" IN ('3') )
ORDER BY lvuad."pos" ASC
OFFSET 0 ROWS FETCH NEXT 2147483647 ROWS ONLY
and I got it to appear on checkout\standard page address-delivery-body-standard.php
<?php foreach( $this->get( 'addressDeliveryValues', '' ) as $addr ) : ?>
    Lastname: <?=  $addr['order.base.address.lastname']; ?>
    Custid: <?=  $addr['custid']; ?>
but Unfortunately still not on the checkout\confirm page order-body-standard.php
    Lastname:  <?= $addr->get( 'order.base.address.lastname' ); ?><br>
    Custid: : <?= $addr->get( 'custid' ); ?>	<br>
Post by aimeos » 29 Sep 2021, 12:02
You need another decorator for the order/base/address manager to tell it how the custid should be stored/retrieved just like you've did for the customer/address manager.
