Category based Product Filter
Rafeel
Post by Rafeel » 24 Sep 2021, 11:09
While filter with in specific category result getting displayed products from all categories.
Re: Category based Product Filter
Post by aimeos » 26 Sep 2021, 10:19
Please add your used Aimeos version and can you reproduce the issue at https://laravel.demo.aimeos.org/ or https://themes.demo.aimeos.org/
Rafeel
Post by Rafeel » 29 Sep 2021, 05:34
Aimeos version: "aimeos/aimeos-laravel": "2021.07.*"
Yes. I am able to replicate the same at https://laravel.demo.aimeos.org/ and https://themes.demo.aimeos.org/
For example here https://themes.demo.aimeos.org/ select the Best sellers category and apply the filter price 0 to 25. Only one product (GIFT VOUCHER) need to be listed. But the same listing from all categories instead of the selected one (Best Seller).
Post by aimeos » 30 Sep 2021, 07:42
Ok, confirmed. This is because the catalog filter component isn't part of the filters on the left any more. Thus, the category isn't passed when the filters are used and the selected category is lost. We will see how we can fix that.
Rafeel
Post by Rafeel » 01 Oct 2021, 09:28
Thanks. Could you please suggest an approach or ideas to give some solution for the same?.
Post by aimeos » 02 Oct 2021, 12:55
Rafeel
Post by Rafeel » 04 Oct 2021, 06:19
Thanks a lot...
