Exend Delivery Service provider and decorator
Kevin1596
Post by Kevin1596 » 06 Oct 2021, 03:33
Aimeos Laravel - 2021.04.3
Thank you for all your supports,
Currently I am trying to extend Delivery service provider and decorator
My use case is Calculating Delivery pricing Base on the Service Attributes user selected from Json api
Could you give me a guide for that?
I have some questions here:
1) How to extend
	public function calcPrice( \Aimeos\MShop\Order\Item\Base\Iface $basket ) : \Aimeos\MShop\Price\Item\Iface
to get the user selected attributes as the
	public function setConfigFE( \Aimeos\MShop\Order\Item\Base\Service\Iface $orderServiceItem,
		array $attributes ) : \Aimeos\MShop\Order\Item\Base\Service\Iface
2) currently, Service proivder will call the function calcPrice before the function setConfigFE
so the code
			$service = $this->getBasketService( $basket, $type, $this->getServiceItem()->getCode() );
will be null due to no Attributes is add to basket service.
How could I change the order the provider execute to make the provider run setConfigFE before calcPrice
Thank you for your help!
Kevin1596
Re: Exend Delivery Service provider and decorator
Post by Kevin1596 » 06 Oct 2021, 03:35
my idea is extend the
to get attributes as
public function calcPrice( \Aimeos\MShop\Order\Item\Base\Iface $basket, array $attributes ) : \Aimeos\MShop\Price\Item\Iface
how could I do that?
Post by aimeos » 07 Oct 2021, 07:47
Extending the signature of the calcPrice() method isn't a good idea but we can try to set the attributes first in the basket service. Do you know where the order needs to be changed?
