Route to display all products, regardless sites
godadada@yahoo.com
Post by godadada@yahoo.com » 11 Oct 2021, 10:26
Greetings,
I am looking for route to display all products of all sites. I do not see any available. aimeos_home does not do the work.
How should I approach it? suggestions, pointers, references, examples will greatly appreciated.
Regards,
Re: Route to display all products, regardless sites
Post by aimeos » 12 Oct 2021, 16:43
No, that's not supported because sites are strictly separated shops of potentially unknown users.
The only option is the marketplace extension from the Aimeos company, which allows you to have a tree of sites and the parent site can display all trees from the child sites:
https://aimeos.com/extensions#c436
