use tables in product long text
whatdaro
Post by whatdaro » 27 Oct 2021, 12:48
How can one use tables in the long description for products.
If I enter the html markup for tables it gets stripped after saving.
Is it possible to disable the stripping or any other way to use tables?
Re: use tables in product long text
Post by aimeos » 28 Oct 2021, 06:56
Which Aimeos version do you use?
Aimeos 2021.10 includes CKEditor 5 and should support tables in text.
