Product media depends on selected attribute
MikaelNazarenko
Expert
Post by MikaelNazarenko » 03 Nov 2021, 21:57
Hello, Aimeos !
I have attribute "color", I have attached some colors to product as configurable options. So on FE product detail page I can select specific color. But when I select specific color I would like to show specific media related to selected color and hide other..
Is there some solution for that ?
Thanks a lot!
Re: Product media depends on selected attribute
Post by aimeos » 05 Nov 2021, 07:28
Currently, your attributes must be variant attributes to make that work. For regular attributes, the attribute IDs are not automatically attached to the images. If you change "variant" to NULL here it may already work:
https://github.com/aimeos/ai-admin-jqad ... d.php#L257
If yes, please create a pull request so we can merge the change into the core :-)
MikaelNazarenko
Expert
Post by MikaelNazarenko » 10 Nov 2021, 14:37
Hi Aimeos!
Sorry but for me it is not clear. I figured out how it works with variant attributes - for this I create selection product and add variant products and add attributes to variant products.
But how can it work with one simple product ? I think I have to set the color to each image.. but how ?
Thank you !
Post by aimeos » 12 Nov 2021, 07:48
In fact, it's a bit more complicated and you are right, you have to associate the configurable attributes to the uploaded images somehow. One way would be to extend the "options" subpart of the product panel and add the attributes to the images there. The main problem is that you don't know which attribute belongs to which image.
