how and when does the pdf-body-standard.php template get created?
whatdaro
Post by whatdaro » 13 Nov 2021, 08:19
This file appears to contain information specific to my site so wanted to know at what stage does the file get created and how can one trigger the re-creation of the file, please.
Re: how and when does the pdf-body-standard.php template get created?
Post by aimeos » 14 Nov 2021, 09:50
It will be used when sending the order confirmation e-mail (or in fact any payment related e-mail).
You can trigger resending those e-mails be removing the records in "mshop_order_status" table related to the order with the type "email-payment".
whatdaro
Post by whatdaro » 14 Nov 2021, 15:19
aimeos wrote: 14 Nov 2021, 09:50 It will be used when sending the order confirmation e-mail (or in fact any payment related e-mail).
Thanks for the reply, however I do understand how its used, but I wanted to know how the .php gets created.
It does not appear to be created during installation because it contains my company information hard coded.
So I believe this .php is created as some later point but I would like to know when please, thanks.
Post by aimeos » 15 Nov 2021, 08:21
Either you've changed the file directly (strongly not recommended!) or you have copied it to your own extension and modified it there.
whatdaro
Post by whatdaro » 15 Nov 2021, 10:16
aimeos wrote: 15 Nov 2021, 08:21 Either you've changed the file directly (strongly not recommended!) or you have copied it to your own extension and modified it there.
I'm certain I did not edit this file because I did not know it existed, I only found out about it after testing the order emails, I realised there was a PDF attached and in there I saw that the PDF footer had information from my website's footer.
It was not formatted correctly so I wanted to know what builds that .php file. thanks
whatdaro
Post by whatdaro » 23 Nov 2021, 00:49
Hi Aimeos,
Do you have an update on this please, I need to know that if the changes I make to this file will be reset during the next update or next time I run composer update
Post by aimeos » 23 Nov 2021, 15:48
If you place a copy of the template file in your own extension, it won't be overwritten if you update.
