display order of Variant attributes
whatdaro
Post by whatdaro » 13 Nov 2021, 23:46
Laravel version=2021.10.2
OS: Linux
Hi Aimeos team,
I'd like to know where I can control the order the Variant product attributes are displayed please.
Also how to change from dropdown select to radio buttons, the documentation on this is not all that clear, thanks.
Kind Regards,
Jay
Re: display order of Variant attributes
Post by aimeos » 14 Nov 2021, 09:56
The order of the attributes is determined by the order you add them in the admin backend.
Use these configuration settings to switch between drop-down and buttons for variant attributes:
https://aimeos.org/docs/2021.x/config/c ... tion/#type
