product import job not running
whatdaro
Post by whatdaro » 16 Nov 2021, 18:52
Aimeos : 21.10.2
OS: Linux
running from shell: php artisan aimeos:jobs "admin/cache admin/log catalog/import/csv order/cleanup/unpaid product/import/csv product/bought index/rebuild index/optimize product/export/sitemap subscription/process/begin subscription/process/renew subscription/process/end"
This works fine for order email jobs, but the product/import/csv does not work.
I'm using the example from the documentation
added to the shop.php file
'controller' => [
'jobs'=> [
'product' => [
'import' => [
'csv' => [
'backup' => './storage/imported/import.zip'
'location' => './storage/csv_import/products-import-example.csv',
'skip-lines' => 1,
'mapping' =>
'item' => [
1 => 'product.label', // UTF-8 encoded text, also used as product name
2 => 'product.type', // type of the product, e.g. "default" or "selection"
3 => 'product.status', // enabled (1) or disabled (0)
'text' => [
6 => 'text.type', // e.g. "long" for long description
7 => 'text.content', // UTF-8 encoded text
The csv file is the one from the example.
There are no logs generated and no errors, I'm assuming I missed something or something is not set up properly.
whatdaro
Re: product import job not running
Post by whatdaro » 16 Nov 2021, 20:40
I've worked out that my format of the array in shop.php was not structured properly.
I've fixed that, but now the products get updated but the image is not getting added.
I've tried multiple ways to enter the file name. could you please let me know what is the exact format required for the file path to work, also there are no errors for this so don't know where its going wrong, thanks.
Post by aimeos » 17 Nov 2021, 10:05
The image URLs in the CSV file must be relative to the ./public/aimeos/ directory of your Laravel installation and the images need to be stored there or in a sub-directory thereof.
