Difference between global and local decorators
krzysiekp
Post by krzysiekp » 19 Nov 2021, 08:26
What is the difference between global and local decorators ?
Re: Difference between global and local decorators
Post by aimeos » 19 Nov 2021, 10:11
Global decorators work for all managers, controllers and clients which implements the common interface.
Local decorators will only work with the manager, controller and client that implements the same interface.
Examples:
Global HTML client decorator can be used with any HTML client, e.g. account/history, catalog/detail, checkout/standard, etc.
Local HTML client decorator can be only used for the HTML client it's written for, e.g. catalog/detail
