Decorator process method not working correctly
krzysiekp
Post by krzysiekp » 19 Nov 2021, 16:14
I have a code. Code below line:
$this->getClient()->process();
not working correctly. For example remove product from cart not working.
class BasketDecorator extends \Aimeos\Client\Html\Common\Decorator\Base implements \Aimeos\Client\Html\Common\Decorator\Iface
    public function process()
        try {
            if (Request::input('b_action') === 'add') {
                \Aimeos\Controller\Frontend::create($context, 'basket')->clear();
        } catch (\Exception $ex) {
        $cardType = Session::get('card_type');
        if (empty($cardType)) {
            header('Location: /shop');
            die;
        $count = \Aimeos\Controller\Frontend::create($context, 'basket')->get()->getProducts()->count();
        if ($count > 0) {
            header('Location: /shop/checkout/onepage');
            die;
        } else {
            die;
Re: Decorator process method not working correctly
Post by aimeos » 20 Nov 2021, 10:06
Did you configure your decorator so it will be used? Check if the code is executed at all.
krzysiekp
Post by krzysiekp » 20 Nov 2021, 12:31
Aimeos
I want to execute all base operations of basket and then my code in decorator but not working correctly
Post by aimeos » 21 Nov 2021, 14:30
You didn't answer any of our questions ...
krzysiekp
Post by krzysiekp » 22 Nov 2021, 07:37
Yes, I configured it. I check this code. The code is executing.
Post by aimeos » 22 Nov 2021, 09:21
If you want to execute the basket process() method first, you need to call "$this->getClient()->process();" as first statement in the process() method of your decorator.
krzysiekp
Post by krzysiekp » 22 Nov 2021, 09:23
That's exactly what I do but not working correctly.
