Remove currency from URL in catalogue list
tomrose
Post by tomrose » 23 Nov 2021, 11:52
The catalogue list add a parameter C=EUR (as well as others).
I would like to get rid of this parameter, as EUR is the only currency available.
For catalogue.filter there is remove-params, but not for catalogue.list.
How can I remove parameters from the generated URL?
Thanks.
Re: Remove currency from URL in catalogue list
Post by aimeos » 25 Nov 2021, 13:37
The parameter are only added if you've added the locale/select plugin and used that to switch the language or currency. Otherwise, the language or currency parameters are not part of the URL.
Remove the locale/select plugin and clear all caches.
MirkoDz
Post by MirkoDz » 04 Oct 2024, 10:14
By removing the 'locale/select' plugin, we lose both the language and currency switchers.
Ideally, we'd like to manage locale and currency as route prefixes (e.g., site-url.test/{locale}/{currency}) instead of using query parameters, as the latter isn't an ideal option.
However, there's no straightforward way to configure this. Any suggestions?
