Stripe Integration in Marketplace mode
3hpart
Post by 3hpart » 30 Nov 2021, 19:38
Hi!
Do any of you use the Marketplace extension with Stripe as payment provider?
As a marketplace operator, we take a percentage of the transaction that takes place between vendor and customer (transaction fees).
This means that payment takes place on the platform between vendor and customer (via Stripe) and we also receive something from it.
I'm curious to know who of you also uses the marketplace extension and charges in this way, so that we can learn from you :idea:
Thank you for your feedback.
Re: Stripe Integration in Marketplace mode
Post by aimeos » 02 Dec 2021, 12:12
You need to use Strip Connect which can handle split payments.
