Changing root site code from default breaks parts of site
DmS
Post by DmS » 20 Dec 2021, 15:34
Hi.
Customer wants the url to be <domain>/marketplace/<category/product etc>
So I've changed the shop domain in admin configuration -> settings from default to marketplace
Then I've removed the /shop in shop.php for default prefix :
'default' => ['prefix' => '{site}/', 'middleware' => ['web']],
Most of the things now works as they should, but if I go to <domain>/ i get a fatal error "locale missing"
I've traced this to the https://github.com/aimeos/aimeos-larave ... hp#L57-L66 and the View.php in the same folder where the locale is hard-defaulted to "default" if locale is null.
Is there a way to override/control this in my extension?
Thanx/Dan
_____________
Laravel 8 with Aimeos 2021.10.7 + Marketplace. Setup via composer. Mac with Valet and MySql 8.0.25
Re: Changing root site code from default breaks parts of site
Post by aimeos » 21 Dec 2021, 15:44
Your site setup doesn't seem to be correct.
If you want custom domains for vendor sites, your configuration in your config/shop.php must look like:
'routes' => [
    'admin' => ['domain' => '{site}', 'prefix' => 'admin', 'middleware' => ['web']],
    'jqadm' => ['domain' => '{site}', 'prefix' => 'admin/jqadm', 'middleware' => ['web', 'auth']],
    'jsonadm' => ['domain' => '{site}', 'prefix' => 'admin/jsonadm', 'middleware' => ['web', 'auth']],
    'jsonapi' => ['domain' => '{site}', 'prefix' => 'jsonapi', 'middleware' => ['web', 'api']],
    'account' => ['domain' => '{site}', 'prefix' => 'profile', 'middleware' => ['web', 'auth']],
    'default' => ['domain' => '{site}', 'prefix' => 'shop', 'middleware' => ['web']],
    'update' => ['domain' => '{site}'],
For more information have a look at:
https://aimeos.org/docs/latest/laravel/ ... he-routing
DmS
Post by DmS » 22 Dec 2021, 08:39
Might have been unclear here.
I have one domain, that's the same for all. I don't want separate domains for the vendor sites.
I'm using the marketplace extension, so all "sub-sites" have their own name/site-code, but the parent site sitecode is named "default" in the original installation. So the standard url to the shop where I can shop from all sub-sites/vendors becomes https://mycustomersshop.com/default/shop/
What I'd like the overall url to be is: https://mycustomersshop.com/marketplace/shop/
That's why I want to change the site-code "default" to marketplace, but in the https://github.com/aimeos/aimeos-larave ... hp#L57-L66 the locale hard coded to "default" if it's null.
/Dan
_____________
Post by aimeos » 23 Dec 2021, 12:11
It's correct that there's a fallback to "default" if no site ID is available in the URL. It should be no problem to make that configurable, so this has been changed in dev-master and 2021.10.x-dev:
https://github.com/aimeos/aimeos-larave ... 81bf3b5cca
Install 2021.10.x-dev first:
composer req aimeos/aimeos-laravel:2021.10.x-dev
Then, adapt the default site code in your config/shop.php using:
'site_default' => 'marketplace'
DmS
Post by DmS » 23 Dec 2021, 13:40
Great!
Thank you, that was pretty much the solution I was thinking of, but didn't want to do in core files :)
A merry Christmas and a happy new year to you all!
_____________
Post by aimeos » 23 Dec 2021, 14:03
We've renamed the config to:
'mshop' => [
	'locale' => [
		'site' => 'marketplace'
Reason is that it's now the same configuration as we use in other integrations.
