Aimeos Headless - Session Handler
As mentioned by Norbert in his email, we need to switch the "laravel aimeos adapter" to adapt the aimeos works with JWT, so here is my questions:
- from where and how we should change this adapter ?
- any suggestions for "laravel aimeos adapter" alternative that works with JWT?
OS: Mac
Aimeos Ver: dev-master
Laravel: v8.75
PHP: v8.0.12
DB: MySQL
Tnx.
Kappa Dev.
OS: Mac
Laravel: v8.75
PHP: v8.0.12
DB: MySQL
Tnx.
Kappa Dev.
Re: Aimeos Headless - Session Handler
We need to store the session data in a database table, similar to the madmin_cache table and must consist of the JWT token, the content and a mtime field so we can remove old entries again:
madmin_session
- id VARCHAR (255 chars)
- content TEXT (2GB)
- mtime DATETIME
The content should be JSON encoded or PHP serialized array (depending on performance) of key/value pairs.
The JWT session class must implement this interface:
https://github.com/aimeos/aimeos-core/b ... /Iface.php
Then, we can overwrite the context class from the aimeos-laravel package in the aimeos-headless code and add the JWT session implementation there:
https://github.com/aimeos/aimeos-larave ... #L252-L257
madmin_session
- mtime DATETIME
