Custom CMS redirecting to home page
skydev
Post by skydev » 25 Dec 2021, 04:47
I have added one extra component in cms sections with category selection options.
For the front side, I have added a subpart in CMS sections for that but once I have viewed the cms page it will automatically redirect to the home page.
Can anyone please let us know any solution for the same?
Re: Custom CMS redirecting to home page
Post by aimeos » 25 Dec 2021, 08:53
Which version do you use? Please post the output of "composer show"
skydev
Post by skydev » 25 Dec 2021, 12:43
I use the latest version of aimeos.
Please check the output of composer show.
aimeos/ai-admin-jqadm              2021.10.7 Aimeos Vue.js+Bootstrap admin interface
aimeos/ai-admin-jsonadm            2021.10.3 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html              2021.10.8 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi           2021.10.2 Aimeos JSON API extension
aimeos/ai-cms-grapesjs             2021.10.1 Aimeos GrapesJS CMS extension
aimeos/ai-controller-frontend      2021.10.3 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs          2021.10.5 Aimeos ai-controller-jobs extension
aimeos/ai-gettext                  2021.10.2 Aimeos Gettext extension
aimeos/ai-laravel                  2021.10.1 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer              2021.10.1 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                 2021.10.9 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel              2021.10.4 Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
aimeos/map                         2.5.0     Easy and elegant handling of PHP arrays as array-like map objects similar to jQuery and Laravel Collections
asm89/stack-cors                   v2.0.3    Cross-origin resource sharing library and stack middleware
brick/math                         0.9.3     Arbitrary-precision arithmetic library
dflydev/dot-access-data            v3.0.1    Given a deep data structure, access data by dot notation.
doctrine/cache                     2.1.1     PHP Doctrine Cache library is a popular cache implementation that supports many different drivers such as redis, memcache, apc, mongodb and others.
doctrine/dbal                      2.13.6    Powerful PHP database abstraction layer (DBAL) with many features for database schema introspection and management.
doctrine/deprecations              v0.5.3    A small layer on top of trigger_error(E_USER_DEPRECATED) or PSR-3 logging with options to disable all deprecations or selectively for packages.
doctrine/event-manager             1.1.1     The Doctrine Event Manager is a simple PHP event system that was built to be used with the various Doctrine projects.
doctrine/inflector                 2.0.4     PHP Doctrine Inflector is a small library that can perform string manipulations with regard to upper/lowercase and singular/plural forms of words.
doctrine/instantiator              1.4.0     A small, lightweight utility to instantiate objects in PHP without invoking their constructors
doctrine/lexer                     1.2.1     PHP Doctrine Lexer parser library that can be used in Top-Down, Recursive Descent Parsers.
dragonmantank/cron-expression      v3.1.0    CRON for PHP: Calculate the next or previous run date and determine if a CRON expression is due
egulias/email-validator            2.1.25    A library for validating emails against several RFCs
enshrined/svg-sanitize             0.14.1    An SVG sanitizer for PHP
facade/flare-client-php            1.9.1     Send PHP errors to Flare
facade/ignition                    2.17.2    A beautiful error page for Laravel applications.
facade/ignition-contracts          1.0.2     Solution contracts for Ignition
fakerphp/faker                     v1.17.0   Faker is a PHP library that generates fake data for you.
filp/whoops                        2.14.4    php error handling for cool kids
fruitcake/laravel-cors             v2.0.4    Adds CORS (Cross-Origin Resource Sharing) headers support in your Laravel application
graham-campbell/result-type        v1.0.4    An Implementation Of The Result Type
guzzlehttp/guzzle                  7.4.1     Guzzle is a PHP HTTP client library
guzzlehttp/promises                1.5.1     Guzzle promises library
guzzlehttp/psr7                    2.1.0     PSR-7 message implementation that also provides common utility methods
hamcrest/hamcrest-php              v2.0.1    This is the PHP port of Hamcrest Matchers
laminas/laminas-diactoros          2.8.0     PSR HTTP Message implementations
laravel/framework                  v8.75.0   The Laravel Framework.
laravel/sail                       v1.12.10  Docker files for running a basic Laravel application.
laravel/sanctum                    v2.12.2   Laravel Sanctum provides a featherweight authentication system for SPAs and simple APIs.
laravel/serializable-closure       v1.0.5    Laravel Serializable Closure provides an easy and secure way to serialize closures in PHP.
laravel/tinker                     v2.6.3    Powerful REPL for the Laravel framework.
laravel/ui                         v3.4.0    Laravel UI utilities and presets.
league/commonmark                  2.1.0     Highly-extensible PHP Markdown parser which fully supports the CommonMark spec and GitHub-Flavored Markdown (GFM)
league/config                      v1.1.1    Define configuration arrays with strict schemas and access values with dot notation
league/flysystem                   1.1.9     Filesystem abstraction: Many filesystems, one API.
league/mime-type-detection         1.9.0     Mime-type detection for Flysystem
mockery/mockery                    1.4.4     Mockery is a simple yet flexible PHP mock object framework
monolog/monolog                    2.3.5     Sends your logs to files, sockets, inboxes, databases and various web services
myclabs/deep-copy                  1.10.2    Create deep copies (clones) of your objects
nesbot/carbon                      2.55.2    An API extension for DateTime that supports 281 different languages.
nette/schema                       v1.2.2    📐 Nette Schema: validating data structures against a given Schema.
nette/utils                        v3.2.6    🛠  Nette Utils: lightweight utilities for string & array manipulation, image handling, safe JSON encoding/decoding, validation, slug or strong passw...
nikic/php-parser                   v4.13.2   A PHP parser written in PHP
nunomaduro/collision               v5.10.0   Cli error handling for console/command-line PHP applications.
nyholm/psr7                        1.4.1     A fast PHP7 implementation of PSR-7
opis/closure                       3.6.2     A library that can be used to serialize closures (anonymous functions) and arbitrary objects.
phar-io/manifest                   2.0.3     Component for reading phar.io manifest information from a PHP Archive (PHAR)
phar-io/version                    3.1.0     Library for handling version information and constraints
php-http/message-factory           v1.0.2    Factory interfaces for PSR-7 HTTP Message
phpdocumentor/reflection-common    2.2.0     Common reflection classes used by phpdocumentor to reflect the code structure
phpdocumentor/reflection-docblock  5.3.0     With this component, a library can provide support for annotations via DocBlocks or otherwise retrieve information that is embedded in a DocBlock.
phpdocumentor/type-resolver        1.5.1     A PSR-5 based resolver of Class names, Types and Structural Element Names
phpoption/phpoption                1.8.1     Option Type for PHP
phpspec/prophecy                   v1.15.0   Highly opinionated mocking framework for PHP 5.3+
phpunit/php-code-coverage          9.2.10    Library that provides collection, processing, and rendering functionality for PHP code coverage information.
phpunit/php-file-iterator          3.0.6     FilterIterator implementation that filters files based on a list of suffixes.
phpunit/php-invoker                3.1.1     Invoke callables with a timeout
phpunit/php-text-template          2.0.4     Simple template engine.
phpunit/php-timer                  5.0.3     Utility class for timing
phpunit/phpunit                    9.5.10    The PHP Unit Testing framework.
psr/container                      1.1.2     Common Container Interface (PHP FIG PSR-11)
psr/event-dispatcher               1.0.0     Standard interfaces for event handling.
psr/http-client                    1.0.1     Common interface for HTTP clients
psr/http-factory                   1.0.1     Common interfaces for PSR-7 HTTP message factories
psr/http-message                   1.0.1     Common interface for HTTP messages
psr/log                            1.1.4     Common interface for logging libraries
psr/simple-cache                   1.0.1     Common interfaces for simple caching
psy/psysh                          v0.10.12  An interactive shell for modern PHP.
ralouphie/getallheaders            3.0.3     A polyfill for getallheaders.
ramsey/collection                  1.2.2     A PHP library for representing and manipulating collections.
ramsey/uuid                        4.2.3     A PHP library for generating and working with universally unique identifiers (UUIDs).
sebastian/cli-parser               1.0.1     Library for parsing CLI options
sebastian/code-unit                1.0.8     Collection of value objects that represent the PHP code units
sebastian/code-unit-reverse-lookup 2.0.3     Looks up which function or method a line of code belongs to
sebastian/comparator               4.0.6     Provides the functionality to compare PHP values for equality
sebastian/complexity               2.0.2     Library for calculating the complexity of PHP code units
sebastian/diff                     4.0.4     Diff implementation
sebastian/environment              5.1.3     Provides functionality to handle HHVM/PHP environments
sebastian/exporter                 4.0.4     Provides the functionality to export PHP variables for visualization
sebastian/global-state             5.0.3     Snapshotting of global state
sebastian/lines-of-code            1.0.3     Library for counting the lines of code in PHP source code
sebastian/object-enumerator        4.0.4     Traverses array structures and object graphs to enumerate all referenced objects
sebastian/object-reflector         2.0.4     Allows reflection of object attributes, including inherited and non-public ones
sebastian/recursion-context        4.0.4     Provides functionality to recursively process PHP variables
sebastian/resource-operations      3.0.3     Provides a list of PHP built-in functions that operate on resources
sebastian/type                     2.3.4     Collection of value objects that represent the types of the PHP type system
sebastian/version                  3.0.2     Library that helps with managing the version number of Git-hosted PHP projects
swiftmailer/swiftmailer            v6.3.0    Swiftmailer, free feature-rich PHP mailer
symfony/console                    v5.4.1    Eases the creation of beautiful and testable command line interfaces
symfony/css-selector               v5.4.0    Converts CSS selectors to XPath expressions
symfony/deprecation-contracts      v2.5.0    A generic function and convention to trigger deprecation notices
symfony/error-handler              v5.4.1    Provides tools to manage errors and ease debugging PHP code
symfony/event-dispatcher           v5.4.0    Provides tools that allow your application components to communicate with each other by dispatching events and listening to them
symfony/event-dispatcher-contracts v2.5.0    Generic abstractions related to dispatching event
symfony/finder                     v5.4.0    Finds files and directories via an intuitive fluent interface
symfony/http-foundation            v5.4.1    Defines an object-oriented layer for the HTTP specification
symfony/http-kernel                v5.4.1    Provides a structured process for converting a Request into a Response
symfony/mime                       v5.4.0    Allows manipulating MIME messages
symfony/polyfill-ctype             v1.23.0   Symfony polyfill for ctype functions
symfony/polyfill-iconv             v1.23.0   Symfony polyfill for the Iconv extension
symfony/polyfill-intl-grapheme     v1.23.1   Symfony polyfill for intl's grapheme_* functions
symfony/polyfill-intl-idn          v1.23.0   Symfony polyfill for intl's idn_to_ascii and idn_to_utf8 functions
symfony/polyfill-intl-normalizer   v1.23.0   Symfony polyfill for intl's Normalizer class and related functions
symfony/polyfill-mbstring          v1.23.1   Symfony polyfill for the Mbstring extension
symfony/polyfill-php72             v1.23.0   Symfony polyfill backporting some PHP 7.2+ features to lower PHP versions
symfony/polyfill-php73             v1.23.0   Symfony polyfill backporting some PHP 7.3+ features to lower PHP versions
symfony/polyfill-php80             v1.23.1   Symfony polyfill backporting some PHP 8.0+ features to lower PHP versions
symfony/polyfill-php81             v1.23.0   Symfony polyfill backporting some PHP 8.1+ features to lower PHP versions
symfony/process                    v5.4.0    Executes commands in sub-processes
symfony/psr-http-message-bridge    v2.1.2    PSR HTTP message bridge
symfony/routing                    v5.4.0    Maps an HTTP request to a set of configuration variables
symfony/service-contracts          v2.5.0    Generic abstractions related to writing services
symfony/string                     v5.4.0    Provides an object-oriented API to strings and deals with bytes, UTF-8 code points and grapheme clusters in a unified way
symfony/translation                v5.4.1    Provides tools to internationalize your application
symfony/translation-contracts      v2.5.0    Generic abstractions related to translation
symfony/var-dumper                 v5.4.1    Provides mechanisms for walking through any arbitrary PHP variable
tecnickcom/tcpdf                   6.4.2     TCPDF is a PHP class for generating PDF documents and barcodes.
theseer/tokenizer                  1.2.1     A small library for converting tokenized PHP source code into XML and potentially other formats
tijsverkoyen/css-to-inline-styles  2.2.4     CssToInlineStyles is a class that enables you to convert HTML-pages/files into HTML-pages/files with inline styles. This is very useful when you're sen...
vlucas/phpdotenv                   v5.4.1    Loads environment variables from `.env` to `getenv()`, `$_ENV` and `$_SERVER` automagically.
voku/portable-ascii                1.5.6     Portable ASCII library - performance optimized (ascii) string functions for php.
webmozart/assert                   1.10.0    Assertions to validate method input/output with nice error messages.
Post by aimeos » 25 Dec 2021, 13:00
There's a newer version of aimeos/ai-cms-grapesjs (2021.10.2) which should fix the problem. Please run "composer up"
