New admin panel
New admin panel
I am using laravel 8.x, PHP 7.4, Ubuntu and the Aimeos 2021
What is the simplest way to add a new admin panel , i just want to put in a map (Will get info from externat api)
Happy new year !
Happy new year !
Re: New admin panel
If it's for an existing panel like the product, supplier or customer panel, you can create a subpart for your map. In that case, you only need to adapt the get() method and the implement the required template:
https://aimeos.org/docs/latest/admin/jq ... -subparts/
In case it should be a new main panel, you need to implement the search() (and get()) method with the corresponding templates:
https://aimeos.org/docs/latest/admin/jq ... nt-panels/
