Templates not overwriting
Veverica
Post by Veverica » 05 Jan 2022, 11:27
Greetings!
I'm having issues with overwriting the default templates. Here are the steps I took:
Copied the aimeos git repository;
Composer update after creating database
Served up the project. The demo shop appeared, all is well in the world.
Started off by copying the views files from aimeos-laravel into /resources/views/vendor/shop - saw results when messing with these, they seem to work
Then, after reading the documentation for overwriting templates I ran the extension builder and unzipped the project files into the /ext/<myextension>/ folder structure, mimicking the folder structure found in ai-client-html, where /ext is at the root of the project. I copied the template files found in the ai-client-html folder into <myextension> template folder and this is where I get stuck. No matter what change in the templates from <myextension> there seem to be no changes made. Help would be much appreciated!
Laravel Framework 6.20.43
PHP 7.3.31
Aimeos 2021.07
Windows 10
Here is my composer.json found at the root of the project:
    "name": "aimeos/aimeos",
    "description": "Aimeos shop system",
    "keywords": ["Aimeos", "e-commerce", "shop", "laravel", "distribution"],
    "license": "MIT",
    "type": "project",
    "prefer-stable": true,
    "minimum-stability": "dev",
    "repositories": [{
        "type": "composer",
        "url": "https://packages.aimeos.org/aimeoscom"
    "require": {
        "php": "^7.2||^8.0",
        "composer-runtime-api": "^2.1",
        "aimeos/aimeos-laravel": "2021.07.*",
        "aimeos/ai-cms-grapesjs": "2021.07.*",
        "fideloper/proxy": "^4.0",
        "laravel/framework": "^6.20.12",
        "laravel/tinker": "^1.0",
        "laravel/ui": "^1.0"
    "require-dev": {
        "facade/ignition": "^1.4",
        "fzaninotto/faker": "^1.4",
        "mockery/mockery": "^1.0",
        "nunomaduro/collision": "^3.0",
        "phpunit/phpunit": "^8.0||^9.0"
    "config": {
        "optimize-autoloader": true,
        "preferred-install": "dist",
        "sort-packages": true
    "extra": {
        "laravel": {
            "dont-discover": [],
            "providers": [
                "Aimeos\\asusplus\\ExtensionServiceProvider"
    "autoload": {
        "psr-4": {
            "App\\": "app/"
        "classmap": [
            "database/seeds",
            "database/factories",
            "ext/asusplus/client/html/src",
			"ext/asusplus/client/jsonapi/src",
			"ext/asusplus/admin/jqadm/src",
			"ext/asusplus/admin/jsonadm/src",
			"ext/asusplus/controller/common/src",
			"ext/asusplus/controller/frontend/src",
			"ext/asusplus/controller/jobs/src",
			"ext/asusplus/lib/custom/src",
			"ext/asusplus/ExtensionServiceProvider.php"
    "autoload-dev": {
        "psr-4": {
            "Tests\\": "tests/"
    "scripts": {
        "post-autoload-dump": [
            "Illuminate\\Foundation\\ComposerScripts::postAutoloadDump",
            "@php artisan package:discover --ansi"
            "@php -r \"file_exists('.env') || copy('.env.example', '.env');\""
        "post-create-project-cmd": [
            "@php artisan key:generate --ansi",
            "App\\Composer::configure",
            "@php artisan migrate",
            "App\\Composer::setup",
            "App\\Composer::account",
            "App\\Composer::success"
        "post-update-cmd": [
            "@php artisan vendor:publish --tag=public --force",
            "\\Aimeos\\Shop\\Composer::join"
Re: Templates not overwriting
Post by aimeos » 05 Jan 2022, 12:05
Can you post a concrete example of a template you want to overwrite and where you've stored the copy?
Veverica
Post by Veverica » 05 Jan 2022, 12:18
For example I want to overwrite the /catalog/detail/body-standard.php, which I copied to /ext/<myextension>/client/html/templates/catalog/detail/body-standard.php. As previously mentioned, /ext is located at the root of the project.
Post by aimeos » 05 Jan 2022, 12:24
This is perfectly fine, just make sure you clear the cache with:
php artisan aimeos:clear
or disable the cache during development:
https://github.com/aimeos/aimeos-laravel#hints
Veverica
Post by Veverica » 05 Jan 2022, 12:28
Okay, that worked, thanks!
